Jump to content
To register an account on Pes6Stars server, Click here.
To Download Hosts file , Click here.
Come to our Facebook Page, Click here.
Come to our Discord Channel, Click here.
Check Live Matches, Go here.
/ with some friends (who are close with good conn)
Swfcdan
Recommended Posts
My friend has returned but we keep seeing / with each other. We can play with some other hosts but can't host ourselves, yet we are both from UK with good connections. Also a friend in Spain with good connection I see / with.
Do you have any possible solutions for this? Do we need to open ports possibly? We have played pes online together in past many years ago with no trouble then. I cant understand why I can play with others but not him. Also a friend from Spain I have the same problem (/) with.
Can you help, thanks.
Dan
Link to comment
Share on other sites
connection bar in bug before joinning the room
player must need enter the room to see real connection bar
/ happens because of port,firewall,antivirus or defender
sometimes you can see bar on him but he can't see bar on you
if you see bar on him and if he participate as blue, the match can open
if he see bar on you and if you get blue, the match can open
but if both player see / than you or your opponent need open port as 5730 udp or
5730-5739 udp & tcp in nat of router. Server can let you in but you can't play because of /. I know it very well. Do what I'm saying.
thanks for report.. :D
Link to comment
Thanks for responding. We don't use antivirus so think it must be a port issue.
So do you have an explanation as to how to open port 5730 udp? We are pes players but not computer whizzkids unfortunately :)
Link to comment
15 minutes ago, Ahg37 said:
I can help via teamviewer. Because most of routers are very different. If you know the router name and model I can help more from here. Otherwise only teamviewer
I see here you showed a basic way of opening ports:
Third :
Open settings and click "online" tab and write manual port
as 5739 and click ok.
But I tried that and entered 5730 as the port instead as you suggested, but it doesn't seem to have worked (just tested on the server).
I have teamviewer so can use that if you want now? If so send me PM
Link to comment
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
  • Create New...
